Animation module issue
activating shading options in the Model or Sculpt or Patch environments, they aren't reflected in the Animation module.
If I select the Display Settings in the Animation module I see all the activated options checked but non visible on the screen: AO, shadows, AA, etc.
If I deactivate-activate (uncheck-check) the options finally they are visible.
I did a test with an old file where I created an animation.
regards
innovatenate
Autodesk Support
Autodesk Support
It seems that the "Limit all effects to optimize performance" option in the Graphics Diagnostic window may have some impact on this behavior. I note that if I disable this option, updating the Display Effects in the Model/Patch Environment is reflected when switching to the Animation environment. Do you see the same thing?
Nathan Chandler
Principal Specialist
