Hi please see attached they come up at opening and closing fusion 360.
Learn, Grow, Succeed.
The errors was because the addin which you downloaded from Exchange Store didn't work no longer in new Fusion. Those errors popped up when the addin was loaded or stopped.
Please uninstall that addin and download updated one from Exchange Store.
Marshal
@GPTech2444 the app or add-in Marshal is referring to is Exactflat. The latest update to the Exactflat app in the exchange store can be found below...
Thanks, could you give me a run down on how to uninstall the plugins so I don't have to spend time working it out?
Please follow the steps as below to uninstall/reinstall the addin "ExactFlat Online Publisher".
1. Go to Control Panel -> Uninstall a program.
2. Find "ExactPlat Online Publisher" in the application list and uninstall.
3. In case, you cannot find the item in the list. Please go to folder "C:\Users\<Grant>\AppData\Roaming\Autodesk\ApplicationPlugins" and delete the whole folder "ExactFlatOnlinePublisher.bundle".
4. And then go to "https://apps.exchange.autodesk.com/FUSION/en/Detail/Index?id=appstore.exchange.autodesk.com:exactfla... and download the lasted installer for "ExactFlat Online Publisher".
Marshal
Thanks, I'm just completely uninstalling fusion as it is crashing all the time. I'll do a clean install of it.
