Hello. Just wondering, can anyone confirm that these joints can be animated? Trying to join them for three days now, no luck. Thank you in advance.
Solved by HughesTooling. Go to Solution.
Take a look at the attached file. It could do with setting up a bit more carefully but it should give you a good idea how it works. Use New Design From file to open.
Mark
Mark Hughes
Owner, Hughes Tooling
