Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Pinion drive on Rack
2 REPLIES 2
zarsss
459 Views, 2 Replies
Hello. Just wondering, can anyone confirm that these joints can be animated? Trying to join them for three days now, no luck. Thank you in advance.
                Rack and gear
2 REPLIES 2
HughesTooling
in reply to: zarsss
Take a look at the attached file. It could do with setting up a bit more carefully but it should give you a good idea how it works. Use New Design From file to open.
Mark
Mark Hughes
Owner, Hughes Tooling
zarsss
in reply to: HughesTooling
Thank you so much. Tried to recreate and it works perfect.
Technology Administrators
