Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
MOVE data to different Project folder
22 REPLIES 22
Message 1 of 23
tkuechle
5440 Views, 22 Replies
There seems to be an issue for me moving files to a different folder. I could sometimes select several files, right click and then select move. Normally a window would appear that would allow me to move the selected files move files to a destination. Now, when the window appears it is no longer possible to select the new destination when it is a new project folder.
Strange.
Tem
Tags (4)
22 REPLIES 22
Message 21 of 23
veso58S5W
in reply to: veso58S5W
The only way I figured out how I can move files from one Project to other is to Copy those files to the different Project (where I want them) and then delete all of them in the Project I don't want them.
Tedious, unnecessary job.
Message 22 of 23
veso58S5W
Even that doesn't work. Horrible experience.
Message 23 of 23
Phil.E
The only restriction on moving designs across projects is found on an old "single user storage" hub. When you look at your hub list, is your current hub listed as Single User Storage like this example? (see the last item on the list, it's a Single User Storage hub)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
