There seems to be an issue for me moving files to a different folder. I could sometimes select several files, right click and then select move. Normally a window would appear that would allow me to move the selected files move files to a destination. Now, when the window appears it is no longer possible to select the new destination when it is a new project folder.
Strange.
Tem
Solved by tkuechle. Go to Solution.
The only way I figured out how I can move files from one Project to other is to Copy those files to the different Project (where I want them) and then delete all of them in the Project I don't want them.
Tedious, unnecessary job.
The only restriction on moving designs across projects is found on an old "single user storage" hub. When you look at your hub list, is your current hub listed as Single User Storage like this example? (see the last item on the list, it's a Single User Storage hub)
