Is that possible ??
Is that possible ??
budi67
Message 1 of 39
Is that possible ??
budi67
Hi all,
Sorry for my english, i'm French.
I try to make a Dome of R2-D2, i managed to create the panels of the top, but now I should make a hole on a face of one of these panels, is it possible?
The hole
As the surface is spherical!! I don't found
A big thanks
Best regards,
Budi67
Accepted solutions (3)
Replies (38)
Message 21 of 39
michallach81
That's not that bad. Try to draw top view but with hidden arcs, then draw front view (aligne with top view). Draw constuction lines from front view to top view. That will tell you how it's build.
Today is too late for me, but tomorrow I will show you the method.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 22 of 39
budi67
Thanks for your answer and your help.
It is easier when one in the habit of used a soft, It makes only a few days that I put myself in the 3d, but I am persevering lol
Message 23 of 39
michallach81
Hi, that part did looked trivial, but it turned out it was not. On first sight I thought it was all prismatic part. But it turned out that main opening have to non-prismatic surfaces.
I think someone have made mistake. That drawing was (I suspect) done in 2D and that could cause all trouble. There is also bug in dimension. Angle 59deg seems to be just an aproximation.
Below you'll find screencast:
Michał Lach
Designer
co-author
Message 24 of 39
michallach81
And another one, because I forgot about one detail:
Michał Lach
Designer
co-author
Message 25 of 39
budi67
I am really impressed, I would never have made a success of it. One thank you for your help, I am going to study it with big attention.
A big thanks
Message 26 of 39
budi67
I learnt many thing thanks to your screencast, thank you
I have unfortunately an even harder part (for me) to realize. See attached file
Could you tell me with which face you would begin ? I have already tried several way, but without making a success
One are going to say that I still have no eye 3d, I would like to succeed
A screenshot of the progress
Message 27 of 39
michallach81
I will look in to that task, but rather tomorrow.
Michał Lach
Designer
co-author
Message 28 of 39
budi67
Thank you very much for your invaluable help.
Message 29 of 39
michallach81
First drawing in attached pdf is completly messed up. There is semi section view (from unknown plane) and on top of that is overdrawn profile, very misleading. I can say that's very bad example to start with CAD. I will help you, but I need to debug whole process. Since I know what is wrong with first page, we should get what you need.
Michał Lach
Designer
co-author
Message 30 of 39
budi67
Ok, thanks.
I found another but it's only a pattern, if it can help you, I always swim so much
Message 31 of 39
michallach81
I even have found part in .step, this way I was able confirm my suspicions about meaning of first drawing. Be patient i will show you how to do it.
Michał Lach
Designer
co-author
Message 32 of 39
budi67
Ah, cool !!! I am really curious how to begin this part
Christophe
Message 33 of 39
michallach81
Ok, the model is ready but I can't confirm if it's ok. Data in page #4 are inconsistent, where I would expect to see angular dimension , I found distance... There is no enough information about which face is planar to which, etc. Page #5 should serve to confirm dimensions, but these are dimensions relative to some unspecified plane.
I will record screencast tomorrow, today I will only share my file.
Michał Lach
Designer
co-author
Message 34 of 39
budi67
Waouhhh, seems like a children's game for you !!
I would look at this screencast with big interest
A big thanks
Christophe
Message 35 of 39
budi67
I have another problem, i must yet cut the dome in multiple parts to print him.
But I do not arrive there, How to cut by following the red line
A big thanks
Message 36 of 39
TheCADWhisperer
@budi67 wrote:
How to cut by following the red line...
 Sketch the line and then Split Body.
If you modeled with symmetry about the origin - you might be able to use one of the origin planes for the split rather than creating a new sketch.
Message 37 of 39
budi67
Thanks for your answer.
I don't modeled with symetry, i did not succeed like that, I cheated otherwise, it was longer, but I arrived there.
I have every time to take up one walls of every quoted which I then erased
Message 38 of 39
budi67
Hi all,
I once again come back to you because I try to make some things, but in vain.
I would like to integrate hinges, but I does not know how to take myself there.
I have already tried several times unsuccessfully, I would want that panels open as on the photo, which would be the procedure to begin
The dome makes a thickness of 8mm
A big thanks
Budi67
Message 39 of 39
patrick.emin
Bonjour @budi67 pour votre information, nous avons un forum en français Fusion 360 - Français - Autodesk Community
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
