Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to combine two non touching bodies when combine tool don't work
2 REPLIES 2
ludwig9GUSA
141 Views, 2 Replies
following Problem: I try to fill a hole between two non touching objects so it is combined to one body (Image in attachment). The combine tool don't work and I don't know how I can connect them. I am trying to model a joint
2 REPLIES 2
davebYYPCU
in reply to: ludwig9GUSA
Sketch the gap,
Extrude the sketch, set to join.
To make a joint, you don’t have to close the gap.
Might help…..
g-andresen
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
Technology Administrators
