How to combine two non touching bodies when combine tool don't work
2 REPLIES 2
ludwig9GUSA
184 Views, 2 Replies
following Problem: I try to fill a hole between two non touching objects so it is combined to one body (Image in attachment). The combine tool don't work and I don't know how I can connect them. I am trying to model a joint
2 REPLIES 2
davebYYPCU
in reply to: ludwig9GUSA
Sketch the gap,
Extrude the sketch, set to join.
To make a joint, you don’t have to close the gap.
Might help…..
g-andresen
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
