Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Problem with cutting two pieces perfectly. (Beginner)
2 REPLIES 2
chrisboeingr
206 Views, 2 Replies
Hello, im very new to CAD and made my first project today.
Now i have the problem, that i dont know how to properly align the backrest in the corner. Both are coming in an angle and one should go like in front and the other one all the way trough. I tried it out with construction layers but could not snap anything in the sketching mode.
Tags (3)
2 REPLIES 2
jhackney1972
in reply to: chrisboeingr
Please attach your model so the Forum users can use it to show solutions to your problem.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
davebYYPCU
Modify > Split Body.  Cut the low grey one with the front face of the bone coloured one.
Remove the offcut.
You can fix yellow icons, with the Undo command, as soon as they turn up.
Might help…..
