following Problem: I try to fill a hole between two non touching objects so it is combined to one body (Image in attachment). The combine tool don't work and I don't know how I can connect them. I am trying to model a joint
Solved by davebYYPCU. Go to Solution.
Sketch the gap,
Extrude the sketch, set to join.
To make a joint, you don’t have to close the gap.
Might help…..
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
