- Mute
- Permalink
- Report
I feel like I am running around trying to accomplish something that must be quite simple: I have a line and I would like to chamfer part of it.
In the attached screenshot, I have highlighted the 4 places (each time, a 4mm line) when I would lke to "chamfer" to create a notch so that I can deposit my electric toothbrush head.
As you can see, I have even tried to add fake/construction lines so that I could select the part of line to chamfer, but it doesn't work. I tried to play with the split tool, but failed to properly understand how it works, apparently.
In my model you will see that the last step if to add .5mm filet on almost every edge (I feel I'm missing one, but can't find which one... 57 edges seems odd), si I guess I need to chamfer the section of line BEFORE I do the filet.
You can download my model here.
Any guidance would be much appreciated.
