How to chamfer part of a line/edge
twitos
Message 1 of 10
twitos
I feel like I am running around trying to accomplish something that must be quite simple: I have a line and I would like to chamfer part of it.
In the attached screenshot, I have highlighted the 4 places (each time, a 4mm line) when I would lke to "chamfer" to create a notch so that I can deposit my electric toothbrush head.
As you can see, I have even tried to add fake/construction lines so that I could select the part of line to chamfer, but it doesn't work. I tried to play with the split tool, but failed to properly understand how it works, apparently.
In my model you will see that the last step if to add .5mm filet on almost every edge (I feel I'm missing one, but can't find which one... 57 edges seems odd), si I guess I need to chamfer the section of line BEFORE I do the filet.
You can download my model here.
Any guidance would be much appreciated.
Replies (9)
Message 2 of 10
jeevesme
You can't Chamfer a Sketch line.  Hide the Sketch and Chamfer the edges of the body.
Edit:  I Just re-read where you want just the 4mm part chamfered. There are multiple ways to do it but you can Split the body using the sketch, then Chamfer the edges you want.
https://autode.sk/2GnkY5L
https://autode.sk/2J3Ynx0
_________________________________________________________________________________________________________________________________________Forever yours,
Love,
Brian
PS. If this answered your question, please mark as answered so others do not read through the posts trying to figure out if it was answered.
Message 3 of 10
msecco
You can do it using sweep. It's not as simple as using chamfer, but it's a workaround.
iqADcqT
Att.
Mário L. Secco - Professor Secco
3D CAD/CAM/CAE Instructor and consultant
YouTube Channel
Blog
Facebook
Instrutor e consultor de CAD/CAM/CAE 3D
Canal YouTube
Blog
Facebook
Message 4 of 10
Hey there @twitos
I made a screencast for you to illustrate how to use the Split Body command to accomplish the required chamfer
Hope this helps you accomplish the chamfer you were after, feel free to contact me should you need further help!
-Carlos Moreno
Message 5 of 10
twitos
Thank you so much for taking the time to do a screen cam.
I don't know if you guys can see the progress I've made since my OP using the original link to my project..?
I am not familiar with the "patch" feature (but I'll look into it thanks to your video), but I tried to make 2 offset planes, then split the body with those planes and do the chamfer.
After struggling to select all the right (but not the wrong) edges to do a fillet all around, I got the idea to merge all bodies after doing the chamfer, and things look not so bad.
Thank yo all for your help.
Final result:
Message 6 of 10
Great job on the final product! @twitos
I'd like to see a post update with some pictures when it becomes a reality.
Best of luck!
Message 7 of 10
twitos
@Anonymous, I have finally printed this part today. I'm happy with the result. You can see pictures of the printed part here.
Thanks to all for the help.
Message 8 of 10
This is an amazing end product!! Congratulations on your design and I hope to see more of your future creations!
Have an amazing day!
Message 9 of 10
simonXA6PP
Observer
Observer
I want to create a simple chamfer on a single side. I have a 3D object which is .75" x 18" x 36". When I use the chamfer tool on the object I select the front face and it make me select an angle AND length, I don't care about the length I want a simple chamfer, not sure why all these videos start with complex shapes. I am trying to transition from Sketchup to Fusion360. I have tried adding a 45 degree line on the front face of the 3D object, and then extrude, I was able to do this once but cannot recreate my steps.
I have attached screenshots of what I am starting with (the side of a cabinet) and what I need to obtain (the bottom of the cabinet with a simple single 45 degree chamfer
Thanks in advance.
Message 10 of 10
g-andresen
might help?
günther
