3D box design in fusion 360
I am new to AD and I am making a box for my circuits. The box is ready and I have to create holes for the screws with required dimensions. I have a Picture of mechanical specification of the circuit board, I am Uploading the image. In that I dont know what is 3 X4 mean? Can someone explain?
TheCADWhisperer
Center is 3mm from edge in 4 locations.  The hole diameter is 3mm.
Given the width and height of the board - the source obviously is lost.
File>Export and then Attach your *.f3d file here if you can't figure it out.
Thank you!!
Well, My Question is you have attached a photo in Autodesk 360 and when I see the properties the dimensions also match!! I mean WOW!! I have around 4 Circuit boards and I can put them and drill it for screws..
I didn't understand following..
"Given the width and height of the board - the source obviously is lost"
TheCADWhisperer
Is the board 6.98mm x 3.8mm as indicated on the original image or is it really 69.8mm x 3.8mm?
Units?Units?
""Is the board 6.98mm x 3.8mm as indicated on the original image or is it really 69.8mm x 3.8mm?""
Yes it is really 69.8mm x 3.8mm. And the Autodesk 360 also has correct dimentions..I measured it!!
