How can I create knurling on only a specific face?
goodvibrato
goodvibrato
You can see in Sketch31 I attempted to create a path with the intent to project that path onto the appropriate face. The problem is the curve gets cut off and I only get a bunch of disconnected lines on the surface rather than a complete curve that can be swept with a profile. I erased all this from the parametric history since it didn't work. The handle is currently all one body.
Are there any strategies for doing knurling on a specific face? You can see the faces that need to be knurled by looking at the canvas and the knife from the front view. Thanks.
construct a tangential plane to any one point, as per your requirement. then sketch some rectangles in a row and then use PROJECT ON SURFACE feature and carry out the extrusion.
