Fixing the position of a rail in a stile and rail panel
I am new Fusion user after a 2 year break from extensive use of SW.  I am trying to create a stile and rail panel which will be adjacent to a window, and I would like the panel rails to align with the horizontal window mullions.  The first rail component was created from a sketch associated with a mullion in the model, but I cannot figure out how to align the copied rail to align with the lower mullion.  The planes of each are highlighted in the pic.
What command is comparable to a SW symmetric mate?  Any other suggestions on how to accomplish this?
TIA.
Dan
etfrench
Can't do much with a pdf.  Posting your file will get you better help.
Joints are used to align components.  The Support & Learning link at the top of forum has videos on how to create joints.
ETFrench
Understood, the next thing I'll work on figuring out is how to post a  link to my project.
Actually, I figured out how to do what I wanted.  First, I aligned the 2 planes in the center of each, then selected the angled rail, selected "Ground".  When the warning popped up about one component having been moved, I selected "Hold Postion".
Works for me!
Dan
laughingcreek
you can attach a file by export a .f3d file from the file menu, then attach at bottom of post
Thanks!
etfrench
If you attach the file, we can show you how to use joints to fix the relative positions of each part.
ETFrench
