- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everybody!
I'm trying to sweep a circular profile over a straight path and create a cut using the Sweep tool. Crucially, I'd the sweep to have a variable twist. In other words, I'd like the first quarter of the twist to be a 800 degrees, and the rest of the twist to be 700 degrees.
I was able to get a constant twist:
But I'm not able to make the twist a variable one, increasing and/or decreasing along the sweep. I've attached my F3D file.
Note: I have tried to use the Equation Driven Curve add-in to create a curvy sweep path and use that instead of the twist feature in the Sweep tool, but I wasn't able to do it right to get a result similar to the pictures above but just with a variable twist.
