Adding lip/flange to end of cylinder with hole
Hello, I'm making a cylinder adapter that slips over 1" weightlifting equipment and allows me to use 2" olympic plates on it. I've got the cylinder designed but would like to put a flange at the end that would stop the plate (like attached image). Is there a way to do this?
jhackney1972
Your timeline has a lot of other features in it but I started from where you had left the timeline.  I attached your model with a different name.  Screencast on how to do it attached.
John Hackney, Retired
davebYYPCU
Change to Minus / negative direction in the extrude.
Might help....
Thanks @jhackney1972 for the solution and @davebYYPCU for the tip.
Ajay_Kumar_Reddy
adding to @davebYYPCU @jhackney1972 this can also be done using the cylinder in primitives.
create-cylinder
give it a try @Anonymous and I hope you'll love it
