Cannot Move Sketch in Sketch Plane
I hope all is well. Here's the issue:
  • I made a sketch. After several extrusions and other manipulations, I realized that the sketch was off by 3.6mm along a dimension in the sketch plane.
  • Going through the design time-line, I wanted to fix that issue by moving the sketch in the plane of the sketch to correct for that mistake.
  • I can't do that, and I have attached a quick video to show what happens instead.
Please let me know if I should provide anything else. Thanks again.
g-andresen
Please share the file and explain where "3.6 mm" should change.
File > export > save as f3d locally  > attach it to the next post.
günther
My apologies, I actually changed the design quite a bit. I'm going to accept your response as a solution, and not make the same mistake.
g-andresen
Often the connection of a sketch element or dimension to the origin is responsible for this.
günther
