Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
History - group/ungroup history, rearranging grouped history
23 REPLIES 23
Message 1 of 24
macxike
11552 Views, 23 Replies
Hello everyone,
I been playing alot with Fusion 360 lately, and aside for not having snapping features, I am lovin it.
I have 2 questions I can't figure out:
  • In the history timeline, after you group some functions together, a "+/-" symbol appears. I see that you can expand/collaspe the group, but how do you ungroup them?
  • Is it possible to drag history functions in/ out of a history group?
You guys are doing a great job with Fusion. I'm converting my workflow to Fusion 360 soon =D
Thank you in advance for the help!
23 REPLIES 23
Message 2 of 24
SallyYang
in reply to: macxike
Thanks for your feedback. We are very happy that you are enjoy modeling with Fusion.
About your questions, we currently don't support drag&drop items into a group. However you can delete the group and then reform it with new items.
To delete a group, you can collapse the group and right click on it to invoke delete function, then select "Delete group and expand its contents ".
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Message 3 of 24
macxike
in reply to: SallyYang
That will do for now. Thanks a lot Sally.
Now time to cleanup and organize my history...
Message 4 of 24
lkokkone
Thank you 🙂
Message 5 of 24
benguestN73BB
I'd just like to point out that this is not terribly intuitive.
Anytime you have a delete, it's really helpful to be extremely specific about what you are going to delete...
Message 6 of 24
dewaine50
How do I add stuff in the line to the group? I tried dragging and dropping but that won't work
Message 7 of 24
cirrus7-de
I can't see the option "Delete group and expand its contents " by right-clicking the collapsed group in the newest version. Is there a bug or am I doing something wrong?
Message 8 of 24
HughesTooling
in reply to: cirrus7-de
Just select delete from that menu, then you'll get the dialog with the options.
Mark Hughes
Owner, Hughes Tooling
Message 9 of 24
cirrus7-de
in reply to: HughesTooling
Wow. That was kind of embarrassingly easy 😳 I use delete a lot to clean up my history of unnecessary features from time to time. Never thought of  another dialog than "This feature is referenced by other features ..." would pop up. Thanks!
Message 10 of 24
aaronseX28WH
Clicking on "Delete" will popup a dialog allowing the Customer to select Ungroup.
Come on guys...  Obviously this isn't intuitive, look at the number of people asking this question.
Consider at least fixing the menu item text to be clearer, e.g. "Delete / Ungroup", try it out...  Don't even bother localizing this edit initially if your Devs typically resist text changes because of localization overhead.
Message 11 of 24
markT6H5R
There is not even a hint in the context menu that "Delete" might do something other than delete the contents of the group. That's what "Delete" does everywhere else in the app. Some of these UI irregularities are just a constant annoyance. We shouldn't have to search Google for such simple things. A clue in the UI, such as "Delete Grouping ..." with an ellipsis would be helpful to indicate it's something other than the standard "Delete".
Message 12 of 24
aaronseX28WH
in reply to: aaronseX28WH
Does anyone from the product group read these messages?  Ideally we'd get a "we hear you, here's a bug/task tracking number you can monitor to see how long it takes us to make a text change to a menu item..."
Message 13 of 24
eleph67
Hi all, how does it come the option to ungroup features is no longer there in current version of F360? I can either "Delete both groups and its contents" or "Cancel".
Tags (3)
Message 14 of 24
laughingcreek
in reply to: eleph67
still there for me-
Message 15 of 24
eleph67
Not for me! May be the is an option hidden somewhere? I can't believe someone decided to just remove the first radio button!
Message 16 of 24
laughingcreek
probably a bug - @Phil.E ?
Message 17 of 24
If you're making changes...  Consider at least fixing the menu item text to be clearer, e.g. "Delete / Ungroup", try it out...  Don't even bother localizing this edit initially if your Devs typically resist text changes because of localization overhead.
Message 18 of 24
I don't work for AD, so I won't be making any changes
Message 19 of 24
Oh well.  I appreciate who ever creates, maintains and supports Fusion 360.  Cheers!
@eleph67 sorry you're having worse than normal experience.  Fusion360 says I have latest version, for what it's worth I see the expected options in the poorly named feature ( that should be called "Ungroup or Delete Group" instead of "Delete Group" ) .
Fusion 360 2.0.17721 x86_64
Active Plan: Personal
Windows 10 Pro 22H2 (19045.3693)
Message 20 of 24
Phil.E
in reply to: laughingcreek
Without a model I have no idea. I don't have a problem with this dialog. It must be model specific.
Windows:
Mac:
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Technology Administrators
