I am trying to combine step files, but didn't get it properly.
The following is the procedure done by me for combining step files.
- Created a new file.
- Inserted all the step files by right clicking the step file and selected the option "Insert into Current Design".
- The step files are successfully inserted into the new file, after that I selected the Combine option and tried to selecting all the bodies but remains unselect able.
- Then I Googled it, I got an option "Derive".
- I selected the Derive option and selected all the (3) bodies and clicked OK button.
- All the bodies will be created in another new file after that, I tried to combine the bodies but resulting the following error.
Error: There was a problem combining geometry together.
If attempting a Join/Cut/Intersect, try to ensure that the bodies have a clear overlap (problems can occur where faces and edges are nearly coincident).
Failed to Boolean bodies together
All the bodies are exactly coinciding each other, but I don't know why this happens like this.
I am sharing all the 3 step files with cloud link.
And also sharing my procedure in gif format.
I think I done a mistake at somewhere, Please help me for solving this problem.
Thanks in advance.
