Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Getting stuck with simple holes
10 REPLIES 10
Message 1 of 11
Latheboy
464 Views, 10 Replies
I can't seem to create 8 simple 1" diameter holes in the attached tube.  I can create one at time, but when I try to do multiple, I get "no target body found to intersect"  I tried to copy the one hole and paste it multiple times, but can't do that either.  Please advise.  Thanks
10 REPLIES 10
Message 2 of 11
laughingcreek
in reply to: Latheboy
you might just try patterning it. see attached
Message 3 of 11
Christoph_360
Hello
Does this video help?
Mfg
Christoph
Message 4 of 11
Latheboy
in reply to: Christoph_360
Thank you for the video.  Can I trouble you to show how you did the starting hole?  I am still having trouble with "no target body.  Was it a point, then a hole extruded from there?  Thanks,
Message 5 of 11
laughingcreek
@Latheboy wrote:
... I am still having trouble with "no target body. ...
a lot of times you jut have to flip the direction-
Message 6 of 11
jhackney1972
You went to all the trouble to layout your hole centers, why not use them.
John Hackney, Retired
Message 7 of 11
Latheboy
in reply to: jhackney1972
I followed along and can't figure out why when I select "to", and try to select the inside of the tube, I still get the same no target body message unless I select the outside of the tube.  If I select distance, I can create the holes.
Message 8 of 11
jhackney1972
Go back and look at the video a little closer.  After I made the Tangent Sketch, I projected the points, in the center of the tube, yours, onto the new tangent plane.  These projected point are the ones I used for the Hole placements.  In your model you are using the points in the center of the tube.
Message 9 of 11
Latheboy
I guess that happened so fast I missed it.  It makes sense 😁  I should add that to my tool bar.
Thanks very much.  Steve
Message 10 of 11
Christoph_360
Hello
Many ways to model this, in the attachment my way.
Mfg
Christoph
Message 11 of 11
Latheboy
I see.  You created one hole and then patterned the hole across.  Makes sense as well.  I think @jhackney1972 did what he did because I had already placed 8 points.  Thanks for the help
