I can't seem to create 8 simple 1" diameter holes in the attached tube. I can create one at time, but when I try to do multiple, I get "no target body found to intersect" I tried to copy the one hole and paste it multiple times, but can't do that either. Please advise. Thanks
Solved by Christoph_360. Go to Solution.
Solved by jhackney1972. Go to Solution.
Solved by laughingcreek. Go to Solution.
Hello
@Latheboy wrote:I can't seem to create 8 simple 1" diameter holes in the attached tube. I can create one at time, but when I try to do multiple, I get "no target body found to intersect" I tried to copy the one hole and paste it multiple times, but can't do that either. Please advise. Thanks
Does this video help?
Mfg
Christoph
Thank you for the video. Can I trouble you to show how you did the starting hole? I am still having trouble with "no target body. Was it a point, then a hole extruded from there? Thanks,
You went to all the trouble to layout your hole centers, why not use them.
John Hackney, Retired
I followed along and can't figure out why when I select "to", and try to select the inside of the tube, I still get the same no target body message unless I select the outside of the tube. If I select distance, I can create the holes.
Go back and look at the video a little closer. After I made the Tangent Sketch, I projected the points, in the center of the tube, yours, onto the new tangent plane. These projected point are the ones I used for the Hole placements. In your model you are using the points in the center of the tube.
I guess that happened so fast I missed it. It makes sense 😁 I should add that to my tool bar.
Thanks very much. Steve
Hello
Many ways to model this, in the attachment my way.
Mfg
Christoph
I see. You created one hole and then patterned the hole across. Makes sense as well. I think @jhackney1972 did what he did because I had already placed 8 points. Thanks for the help
