Getting stuck with simple holes
10 REPLIES 10
Message 1 of 11
Latheboy
394 Views, 10 Replies
I can't seem to create 8 simple 1" diameter holes in the attached tube.  I can create one at time, but when I try to do multiple, I get "no target body found to intersect"  I tried to copy the one hole and paste it multiple times, but can't do that either.  Please advise.  Thanks
10 REPLIES 10
Message 2 of 11
laughingcreek
in reply to: Latheboy
you might just try patterning it. see attached
Message 3 of 11
Christoph_360
Hello
Does this video help?
Mfg
Christoph
Message 4 of 11
Latheboy
in reply to: Christoph_360
Thank you for the video.  Can I trouble you to show how you did the starting hole?  I am still having trouble with "no target body.  Was it a point, then a hole extruded from there?  Thanks,
Message 5 of 11
laughingcreek
@Latheboy wrote:
... I am still having trouble with "no target body. ...
a lot of times you jut have to flip the direction-
Message 6 of 11
jhackney1972
You went to all the trouble to layout your hole centers, why not use them.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Message 7 of 11
Latheboy
in reply to: jhackney1972
I followed along and can't figure out why when I select "to", and try to select the inside of the tube, I still get the same no target body message unless I select the outside of the tube.  If I select distance, I can create the holes.
Message 8 of 11
jhackney1972
Go back and look at the video a little closer.  After I made the Tangent Sketch, I projected the points, in the center of the tube, yours, onto the new tangent plane.  These projected point are the ones I used for the Hole placements.  In your model you are using the points in the center of the tube.
John Hackney
Retired
Message 9 of 11
Latheboy
I guess that happened so fast I missed it.  It makes sense 😁  I should add that to my tool bar.
Thanks very much.  Steve
Message 10 of 11
Christoph_360
Hello
Many ways to model this, in the attachment my way.
Mfg
Christoph
Message 11 of 11
Latheboy
I see.  You created one hole and then patterned the hole across.  Makes sense as well.  I think @jhackney1972 did what he did because I had already placed 8 points.  Thanks for the help
