Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Fusion 360 - Wrap sketch around cylinder and extrude
spajda.pl
Message 1 of 50
spajda.pl
Hi !
I facing problem with cylinders nad cutting shapes.
As text, and simple object can be cutted from cylinder, more complicated shapes not.
I`m not native english so its hard to subscribe.
My plan is to get cylinder (with some thickness),
sketch shape (for example some flames or flowers) to be around 360degrees of this cylinder.
Then cut/extrude selected shapes around all cylinder.
Pipe feature its not i`m looking for, because i got complicated shapes to cut (like flames).
Any tip or advice will be apprieciated.
Maciej
Replies (49)
Message 21 of 50
TrippyLighting
What exactly does hat have to do with wrapping a sketch around a cylinder ?
Message 22 of 50
bayviewboom
maybe nothing.
i thought to wrap a pipe around an imported curved line. Maybe not?
just looking for solutions.
Should we continue discussion in this thread? if so, i'll post my entire question here.
Or discuss in that other thread i linked?
Or maybe i should start a new thread?
thx
Message 23 of 50
rogierweekers
Look at this video, does extract what you (and I) need.  https://www.youtube.com/watch?v=xN5uqSyG6YA
@spajda.plwrote:
Hi !
Maciej
Message 24 of 50
How can this be done in fusion 360? you have linked solidworks tutorials?
Message 26 of 50
NotTheBeaz
You could probably get away with doing several cuts around the object using the offset from surface tool, similar to SolidWorks wrap feature except the cuts or extrusions will head in the direction of the plane rather than the surface which would make it difficult to use cuts to get a consistent depth the whole way round. However if you are looking to extrude no problem. First create your cylinder, draw the shapes to be extruded, extrude them further than they need to be extruded and then look from the top and do an extruded cut of a circle, concentric to the cylinder at the distant desired and you should get hopefully what you wanted.
Message 27 of 50
sotm
@promm wrote:
@spajda.pl,
At this time we do not have this ability. I responded to another thread that you are on letting you know that it is in our backlog.
Cheers,
Mike Prom
Wow, Really?  Solid Works will do this easy!!
Message 28 of 50
TrippyLighting
Did you go through the entire thread and read all the responses ?
Message 29 of 50
sotm
@TrippyLighting wrote:
Did you go through the entire thread and read all the responses.
So where's the answer?
I don't see no tools in Fusion 360 to do a wrapl!!
Message 30 of 50
TrippyLighting
Thanks, that answered my question 😉
One way to accomplish wraps  is hidden in plain sight in the posts above.
Message 31 of 50
sotm
So how do you wrap?  All you have pointed to are pictures that tell nothing about how to!
Message 32 of 50
rogierweekers
You can do this in sheet metal.
1) Create an arc of 359 degr (circle with very small opening)
2) Create sheet metal flange from the arc.
3) Add a short straight extrude to on of the sides of the open cilinder (you need a straight bit for unfolding)
4) Unfold the part.
5) Create a sketch and extrude on the part
6) Refold the part
7) Remove the straight extrude.
8) Add an extrude to close the cilinder
Message 33 of 50
spajda.pl
I know that in SolidWorks i can do it very fast. That why i use both apps to make complete part. I hope i will use F360 at 100% 🙂
Message 34 of 50
TheCADWhisperer
@spajda.pl
Autodesk Inventor Professional
Message 35 of 50
g-andresen
@sotm   It is true that sketches in Fusion cannot be wrapped around a cylinder. This does not bother me if I can wrap the extrusion of this sketch around this.
In addition to the various tips, @rogierweekers  gave excellent instructions for this process.
günther
Message 36 of 50
sotm
günther
Your answer makes NO sense NOR does it add any value to this thread.
Message 37 of 50
TrippyLighting
@sotm I did not point you to pictures. I asked you to read the earlier posts in this thread and maybe follow the links pointed to in this thread. One of my own posts points to this https://forums.autodesk.com/t5/fusion-360-design-validate/for-everyone-that-wants-a-wrap-function-in...
That is the 1st thread where wrapping in Fusion 360 is explained in depth with screencasts.
Before making further posts it would suit you well do do a little homework!
Message 38 of 50
sotm
I’ll say it again a lot of nice pictures in the beginning of the thread all with no explanations of how. All also on cylinders and nothing tapered like a cone.
Message 39 of 50
TrippyLighting
Are you sure you are able follow simple instructions ?
The link I provided in the  the post you responded to, includes instructions including screencasts on how to wrap stuff around cylindrical objects.
I might add that a cone is not a cylinder. But a cone can also be created with the sheet metal tools (you'll have to search for the threads) so in fact this can be done with a cone as well.
The two screencast below I found in 5 seconds of googling "Fusion 360 wrap". Feeling a little lazy today ?
Message 40 of 50
Is there any update on how to do this?  I want to wrap my sketch around a cylinder and extrude it.  I could do this in SW, but can't find any info on how to do it in Fusion 360 except for this blog.
