- Mute
- Permalink
- Report
I have a problem where Fusion opens, but within a couple of seconds after opening it gives me an error. I use Fusion frequently, and this hasn't happened before. I have read several forum pieces with errors like this. I uninstalled Fusion several times and tracked down and unistalled/ deleted related files when doing so. I have also made sure to run it as administrator. Still giving me the same problem.
Potential causes:
- I started using an add-in last night (highly likely the cause, need help determining if was fully removed).
- Closed Fusion without signing out (hasn't been an issue before).
- I think I may have accidentally deleted/ moved autodesk sync?
- Installed some new browsers...
Here is an image of the error report details. Fusion does not have me signin because I did not sign out last time I used it. So it takes me directly to the model environment. The only thing I could gleam was the unhandled exception.
- Eric
