Hello, everyone,
I have a small problem for a longer time, which I unfortunately cannot solve.
I would like to determine the flow cross-sectional area of two overlapping parts.
As an example I have a ball valve. If a ball valve is completely open, i.e. the opening degree = 100 %, the flow cross-sectional area is pi / 4 * d^2 .
When the ball closes, the cross-section decreases over the angle.
Unfortunately, it is not so easy to determine this cross-section, because the flow cross-section is defined in such a way that the resulting velocity vector points normally to this surface.
A colleague has created an Excel table for a simple case. He did this by placing a plane in the surface and then linking the angle of rotation to the surface in CATIA Kinematics. This resulted in a table with opening angle to the cross-sectional surface.
For more complex geometries, like the ones I have attached here, I unfortunately did not make it and I did not find anybody who would know how to do it.
Does anyone of you have an idea how I could do this with Fusion 360 or any other CAD software or whatever?
To make it more clear what i´m tryining to do, i attached some more screenshots.
I try to get the marked flow area for all given angles.
Hi @jarrao.privat.
Could you share this model? I would like to see it and think about it.
Hello, Leo,
I have only roughly created the model for demonstration purposes.
So I had already deleted it, but I redesigned it again and attached it to this post.
It would be really astonishing if you get the problem solved, because I have already talked to several CAD engineers, but only one of them was able to reproduce a small part of the surface with Catia kinematics.
