Determination of a flow cross section over the angle of a curved geometry
4 REPLIES 4
jarrao.privat
584 Views, 4 Replies
Hello, everyone,
I have a small problem for a longer time, which I unfortunately cannot solve.
I would like to determine the flow cross-sectional area of two overlapping parts.
As an example I have a ball valve. If a ball valve is completely open, i.e. the opening degree = 100 %, the flow cross-sectional area is pi / 4 * d^2 .
When the ball closes, the cross-section decreases over the angle.
Unfortunately, it is not so easy to determine this cross-section, because the flow cross-section is defined in such a way that the resulting velocity vector points normally to this surface.
A colleague has created an Excel table for a simple case. He did this by placing a plane in the surface and then linking the angle of rotation to the surface in CATIA Kinematics. This resulted in a table with opening angle to the cross-sectional surface.
For more complex geometries, like the ones I have attached here, I unfortunately did not make it and I did not find anybody who would know how to do it.
Does anyone of you have an idea how I could do this with Fusion 360 or any other CAD software or whatever?
Labels (5)
4 REPLIES 4
jodom4
in reply to: jarrao.privat
This forum is for discussions about Fusion 360's collaboration tools. I'm moving this post to the Design Document Validate forum where you'll be more likely to get some help.
-Jonathan
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
To make it more clear what i´m tryining to do, i attached some more screenshots.
I try to get the marked flow area for all given angles.
LeonardoBN
Hi @jarrao.privat.
Could you share this model? I would like to see it and think about it.
Leonardo Brunelli do Nascimento
Chemical Engineer
jarrao.privat
in reply to: LeonardoBN
Hello, Leo,
I have only roughly created the model for demonstration purposes.
So I had already deleted it, but I redesigned it again and attached it to this post.
It would be really astonishing if you get the problem solved, because I have already talked to several CAD engineers, but only one of them was able to reproduce a small part of the surface with Catia kinematics.
