Depth of field
Depth of field
tomXMSG
Message 1 of 16
Depth of field
tomXMSG
I can't seem to move the centre of focus for the depth of field in the render scene settings as per the image below.
Any ideas?
Replies (15)
Message 2 of 16
TrippyLighting
Yu have to click somewhere on the object(s)  in the viewport, A green dot (IIRC) appears where you clicked.
That is the focal point the DOF is evaluated around.
Message 3 of 16
tomXMSG
Thanks TrippyLighting. I have tried that. The dot is there but I can't move it.
Message 4 of 16
TrippyLighting
With the "depth of filed" enabled and the arrow icon underneath also enabled , indicated by the blue color, you should be able to click on an object in the viewport and see the green dot move to that pint.
Message 5 of 16
tomXMSG
I agree, but nothing happens when I try!
Message 6 of 16
tomXMSG
I am very new to this software. Might it be to do with how you set up the project at the start?
Message 7 of 16
TrippyLighting
I don't think so. I think it is easiest if you create a screencast and records what you are doing. I use OBS for my screencasts.
Message 8 of 16
tomXMSG
It seems I can't move the dot on the main component but can move the dot to a different component but not back again!
Message 9 of 16
TrippyLighting
Can you please expand the browser so we can see the contents of the bodies folder in each component?
Message 10 of 16
tomXMSG
Message 11 of 16
tomXMSG
Message 12 of 16
laughingcreek
I think he wants the bodies folder expanded also.
is the body set to "unselectable"?
its a mesh body.  doesn't seem to be available for selecting.
Message 13 of 16
tomXMSG
Ok. Can I change that?
Message 14 of 16
TrippyLighting
That is exactly what I tought!
@tomXMSG No, that cannot be changed. My suggestion for a workaround is to create a solid body in the spot you want to focus on and then select it in the render environment. Once you have the focal point set, you should be able to hide the object.
Message 15 of 16
tomXMSG
Forgive my ignorance but can a mesh be turned into a body?
Think I need to go back to basics!
Message 16 of 16
tomXMSG
I have been back to basics and implemented the 'hidden object'. Thank you both!
