Creating a thread...
SA2020
Message 1 of 23
SA2020
Hi Everyone:  I've attached a file that I'm having trouble with creating an internal thread.  I imported the igs into Fusion 360 and created the hole (cylinder) in the center of the part and can't get the thread feature to work.
When I select create, thread, then try to select the hole, it won't allow me to, nothing happens.
What am I missing here?
Thanks.
Accepted solutions (4)
Replies (22)
Message 21 of 23
SA2020
Thanks for the video laughingcreek.
I tried to do the same thing, but it's not working.
I hit create sketch, then right click on sketch 1, hit edit sketch, my part moves to the top view.  When I try to create an arc like you did, it doesn't work.
Message 22 of 23
laughingcreek
Yeah, the screen cast might be a little hard to follow.  I didn't actually hit "create Sketch" to start with, (even though I did pass the mouse over it).  I went straight to "edit sketch" for sketch 1.  after that I hit "C" on the keyboard to start the circle command.  slected the center point and drug out the circle.
Message 23 of 23
SA2020
Success, thank you for the further explanation, worked like a charm.
I appreciate everyone that helped, I now have a model and was able to modify it accordingly.
The final thing I'm hoping to get some help with is title blocks.  In post #7 of this thread is what I'm looking for:
https://forums.autodesk.com/t5/fusion-360-design-validate/how-to-import-drawing-template-into-fusion...
I like the one in post #7 because it has a tolerance box and the ability to insert a picture.  Looking for something like that one, not sure if anyone has something similar or if that one is downloadable somewhere?
