Constrains on custom planes question
Hi.
I've created plane at angle and want to create horizontal line there according to my origin. But it creates horizontal constrain in my custom plane local coordinates. How can I make it in global coordinates? Thank You
For example I have custom plane, that is rotated on some angle, and I have outline I want to project from one of the origin planes along origin axis. Is that possible at all?
laughingcreek
The way you're describing it, these sound like 2 very different questions.
For the first question.  The horizontal and vertical constraints are always going to be relative to the current sketch origin.  You can, however, constrain a line in your current sketch (on the plane at a custom angle)  to be parallel to a line in another sketch (such as a horizontal line in a sketch on an origin plane).
For the second question, I would need more to go on.  A screen shot or something showing what your trying to do would be helpful
Here is screenshot
http://clip2net.com/s/3PiVaEJ
I want to project something on selected sketch from the origin YZ plane, but it should be projected by origin's X axis, not this sketch's local coordinates plane.
laughingcreek
It's not obvious, but project to surface will do what your describing.  Instead of picking a surface, you pick a plane to chose from (in this case the same one the sketch is on)  then set the project type to "along vector", and select the x axis as the vector.
Here's a screen cast-
Wow! Thanks a lot!
