Create a cutlist from an imported STEP file.
perry.josh93
Observer Observer
perry.josh93
Observer
Observer
Is there a simple way to pull the material length data (bounding box data) from a Solidworks native .STEP file? I've converted the bodies to components which allows them to be individually identified on the parts list under the drawing page although the parts table avaliable options are useuless.
I don't want to be adjusting each components properties.
Model attached for those needing it.
perry.josh93
Observer
Observer
As a 'get by' method, I've downloaded the .SVG BOM Creator extension.
Its a little messy but does the job.
https://apps.autodesk.com/FUSION/en/Detail/Index?id=1777906377548870264&appLang=en&os=Win64
