Why cant I intersect these shapes
champshire91
Message 1 of 11
champshire91
I try intersecting these two shapes and it wont let me click on the other one why is this? I can click on the other shapes. Thanks!
Replies (10)
Message 2 of 11
dsouzasujay
Hi @champshire91
Can you attach the design? You can export by File>Export *.f3d/*.f3z file to your local drive and then Attach it here to a Reply.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 11
champshire91
Here you go for some reason now it is allowing me to select them but not confirm. I must of did something when I tried to move them to there own seperate project. I just don't under stand this feature with the intersect/merge
Message 4 of 11
dsouzasujay
Hi @champshire91
im not able to reproduce the issue.
I can Intersect, attached design
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 5 of 11
champshire91
That is weird I don't understand this feature its not working how I want it to. Is there any tutorials out there showing how to use this better? I have the free version but I doubt that is the reason because I can do it with other shapes. Thanks!
Message 6 of 11
jhackney1972
I am guessing you do not want Combine > Intersect, I think you want Combine > Cut and then Remove or hide the unwanted cut bodies.  See if the video is what you want.
John Hackney, Retired
Message 7 of 11
TrippyLighting
My suggestion would be to fix the glaring issues in the timeline and then try again!
There should also probably not be any move- and position capture features in the timeline.
Message 8 of 11
champshire91
Ok thanks! I do I fix those issues?
Message 9 of 11
champshire91
Yeah something like that where I can Remove the area where they touch. For some reason when I tried it, it never worked. I just had to do it another way.
Message 10 of 11
TrippyLighting
Start from scratch!
You deleted the contents of these sketches and ignored the warnings that popped up.
Now the subsequent  extrude features are missing their inputs.
Message 11 of 11
champshire91
OK Thanks!
