Connect line endpoints when using "Pattern"
I would like to create a 3D object that looks like a clock, with center facing posts. I have created the basic sketch, but the final step is connecting the points to make the posts so I can extrude to make the 3D object. However, when I create a spline and set the curvature to match the construction circle, the patterned arcs do not connect to the exist line endpoints.
I am aware of the "trim" function and how to use that instead, but ultimately I want to be able to scale the size of the circles later, and trimming every time is inefficient. Is there a simpler way to do this?
LeonardoBN
Hi @Anonymous.
Could you share the F3D file what you have now, and/or a picture of your objective?
Leonardo Brunelli do Nascimento
Chemical Engineer
laughingcreek
sounds like your patterning the sketch objects.  you'll probably get better results patterning in the solid environment.  hard to say without visuals.
