Connect line endpoints when using "Pattern"
08:18 AM
- Mute
- Permalink
- Report
I would like to create a 3D object that looks like a clock, with center facing posts. I have created the basic sketch, but the final step is connecting the points to make the posts so I can extrude to make the 3D object. However, when I create a spline and set the curvature to match the construction circle, the patterned arcs do not connect to the exist line endpoints.
I am aware of the "trim" function and how to use that instead, but ultimately I want to be able to scale the size of the circles later, and trimming every time is inefficient. Is there a simpler way to do this?
