Change aspect ratio
Change aspect ratio
Message 1 of 8
Change aspect ratio
The aspect ratio is set for a different monitor, than the one I use. It is locked. How do I unlock the image resolution so I can correct the ratio. This is all within the capture image, (screen capture).
Replies (7)
Message 2 of 8
Phil.E
On the list of resolutions there should be one called Custom. Does that let you do what you want?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 8
No it does not. The aspect ratio box is checked and grayed out. So no
matter what I change in the custom aspect ratio box. Nothing changes.
Message 4 of 8
Phil.E
Sorry to hear that. Can you post another screen shot showing this?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 8
innovatenate
Autodesk Support
Autodesk Support
Thanks for posting this. I just tested on my Windows 7 system, but I did not see the issue that you mention. Check out the below Autodesk Screencast.
Can you confirm that I am following the correct steps to reproduce the issue? If this video does not help, could you record an Autodesk Screencast of the behavior?
Nathan Chandler
Principal Specialist
Message 6 of 8
I finally figured out how to change the aspect ratio. However, the resolution is still grayed out at 72. I really want it to be 100.
Message 7 of 8
chengyun.yang
You will need to change from "Pixels" to "Inches" first to change the resolution(Pixels/Inch). See the image below:
Chengyun
Fusion Development Team
Message 8 of 8
Thank you. for the answer.
