cannot start the Static Stress Analysis of a Connecting Rod Assembly
nstevelmans
nstevelmans
I cannot open the tutorial for simulation Connecting Rod Assembly,
I also tried to download the tutorial local and from there open the sample file.
also no luck.
see also the avi
mcmillr
Hi, there does appear to be something wrong with this tutorial file, it should not be showing the split screen after open. You can use the environment selector in the upper left corner to switch to the Model env, or you could click on 'Study' on the toolbar and select Linear Static stress.
Rob McMillan
Software Architect, Fusion Simulation
Rob McMillan
