Fusion 360 Library?
Fusion 360 Library?
Fusion 360 Library?
is there a someway to make a library in fusion like we can in Inventor?
I want some models referenced between projects.
innovatenate
Autodesk Support
Autodesk Support
There is a McMaster Carr library that you can insert from in Fusion. You can also use other libraries such as Tracepart or GrabCAD to quickly create content.
I note that you can also create distributed designs (x-refs).
There are no content center libraries, or iparts like Inventor. Today there are no read-only projects/folders that you can insert content center parts. However, you could create a folder in a project to store commonly used hardware. The projects can be shared with other users.
If you're highly interested in this functionality, you may consider voting up some of the Feature Enhancement requests in the Fusion 360 Ideastation Ideas pertaining to this feature.
I hope that helps.
Nathan Chandler
Principal Specialist
Hi Nathan,
You saved me alot of time browsing the web, and fusion now. A parts library like in Inventor was what i was looking for (and needed).
I've got about 20.000 hours of experience in Inventor, so somethings in fusion makes me frustrated, and some make me excited. In that time I've made lots of parts that i want to use in different variations, in different projects. But i want to reference them, so i can make changes one place
Thanks for the advice!
Best regards,
Lewi Uberg
