Cant move sketch
9 REPLIES 9
Message 1 of 10
aeitto
718 Views, 9 Replies
Cant move sketch
Seriously I don't get why I can't move sketches at all.
Here's my problem:
https://i.imgur.com/UxR3B8v.mp4
Made a sketch and then moved my fence and tried to align it. But I figured out that I could place it in the center and use the rectangular pattern on both sides.
Tags (3)
Labels (2)
9 REPLIES 9
Message 2 of 10
jeff_strater
in reply to: aeitto
hard to say without the design.  Usually, this behavior is because at least one point in the sketch is locked, or otherwise fully constrained, and not free to move.  If you share the design, we can find out more...
Jeff Strater
Engineering Director
Message 3 of 10
davebYYPCU
in reply to: aeitto
I think you have to be editing the sketch.  Some of that sketch appears fully defined.
copy / paste to move between sketches.
Might help....
Message 4 of 10
aeitto
in reply to: jeff_strater
Message 5 of 10
etfrench
in reply to: davebYYPCU
I thought the same, but it's not true.  You can move sketch items when you're not editing a(ny) sketch.
ETFrench
Message 6 of 10
jeff_strater
in reply to: aeitto
thanks.  Assuming this is sketch42, you can see the issue if you edit that sketch.  The outer rectangle geometry is fully constrained and bound to the face here, so is not free to move
if you just select the two lines in the middle, those are free to move
Jeff Strater
Message 7 of 10
aeitto
How can I un-bound these? Idk how this happens
Message 8 of 10
jhackney1972
in reply to: aeitto
@jeff_strater pointed out why, to illustrate how you can release it to move, take a look at the Screencast.
John Hackney, Retired
Message 9 of 10
aeitto
in reply to: jhackney1972
Amazing! Thank you
Message 10 of 10
mjflander
Solved.  THANK YOU.
