Cant move sketch
9 REPLIES 9
Message 1 of 10
aeitto
788 Views, 9 Replies
Cant move sketch
aeitto
Seriously I don't get why I can't move sketches at all.
Here's my problem:
https://i.imgur.com/UxR3B8v.mp4
Made a sketch and then moved my fence and tried to align it. But I figured out that I could place it in the center and use the rectangular pattern on both sides.
Cant move sketch
Here's my problem:
Tags (3)
Labels (2)
9 REPLIES 9
Message 2 of 10
jeff_strater
in reply to: aeitto
jeff_strater
hard to say without the design.  Usually, this behavior is because at least one point in the sketch is locked, or otherwise fully constrained, and not free to move.  If you share the design, we can find out more...
Jeff Strater
Engineering Director
Jeff Strater
Message 3 of 10
davebYYPCU
in reply to: aeitto
davebYYPCU
I think you have to be editing the sketch.  Some of that sketch appears fully defined.
copy / paste to move between sketches.
Might help....
Might help....
Message 4 of 10
aeitto
in reply to: jeff_strater
aeitto
Message 5 of 10
etfrench
in reply to: davebYYPCU
etfrench
I thought the same, but it's not true.  You can move sketch items when you're not editing a(ny) sketch.
ETFrench
ETFrench
Message 6 of 10
jeff_strater
in reply to: aeitto
jeff_strater
thanks.  Assuming this is sketch42, you can see the issue if you edit that sketch.  The outer rectangle geometry is fully constrained and bound to the face here, so is not free to move
if you just select the two lines in the middle, those are free to move
Jeff Strater
Jeff Strater
Message 7 of 10
aeitto
aeitto
How can I un-bound these? Idk how this happens
Message 8 of 10
jhackney1972
in reply to: aeitto
jhackney1972
@jeff_strater pointed out why, to illustrate how you can release it to move, take a look at the Screencast.
John Hackney, Retired
Message 9 of 10
aeitto
in reply to: jhackney1972
aeitto
Amazing! Thank you
Amazing! Thank you
Message 10 of 10
mjflander
mjflander
Community Visitor
Community Visitor
Solved.  THANK YOU.
Solved.  THANK YOU.
