Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Can't extrude text
26 REPLIES 26
Message 1 of 27
difalkner
42890 Views, 26 Replies
Can't extrude text
I created the text identically for each line but the one line beginning 'Countless...' returns an error- Inconsistent Edge Face Relationship'. I deleted it and created it again to no avail.
The same problem existed for the line below, 'and many...' but when I recorded the screencast it actually worked.
Thanks for helping!
David
PS - my screencast didn't show up in the dropdown so here's the link -
http://autode.sk/2wmOHro
David Falkner
26 REPLIES 26
Message 21 of 27
beananimal
in reply to: imjamessanford
Still a problem - nothing like fixing bugs.
Message 22 of 27
etfrench
in reply to: beananimal
It won't help if you don't provide any details.  Which font are you using? What is your workflow? Are you exploding the text, extruding it, or just creating the toolpath directly?  Attach your file and a screencast if you are interested in having Autodesk fix the issue.  Just complaining is not effective.
ETFrench
Message 23 of 27
Urbanthor
in reply to: difalkner
can confirm that this bug still exists. I extruded the text fine. Then I added a new text and suddenly I can't extrude at all. font change doesn't help either.
Message 24 of 27
g-andresen
in reply to: Urbanthor
Please start a new thread, share the file and tell what font is used.
File > export > save as f3d on local drive  > attach it to the post.
günther
Message 25 of 27
zohrabyan
same here! spend all day trying to write a text on a box! Fusion 360 is hell of a buggy software! not nice at all
Message 26 of 27
g-andresen
in reply to: zohrabyan
Please start a new thread and attach a sample file to your question.
File > Export > save as f3d on local drive > attach to post
günther
Message 27 of 27
williameaton
I had this same issue with a custom font. However, after switching the file format of the font from otf to ttf, I could extrude it. Since I'm on a mac, all I had to do was delete the existing font from the Font Book application and replace it with the ttf file. You can convert otf files to ttf files online too so it was really easy. Don't forget to restart Fusion 360 after you've replaced the file though.
Tags (1)
