3/8" Compression Fitting Thread
benoitmeunier
benoitmeunier
I’ve been using Fusion360 for a while now and I’m comfortable creating NPT threads. However, I’m struggling with creating female compression fittings threads, specifically 3/8” for plumbing purposes.
I’ve followed various tutorials and tried different techniques, but I still can’t seem to get it right. Am I missing something fundamental? Could someone point me in the right direction or share any resources that could help?
Thanks in advance for your assistance!
MRWakefield
I've just done a very quick search and it would appear to be 3/8" BSP (G3/8) (for 15mm copper pipe). Is this what you're looking for? If so you'll find it in various guises:
Hope this helps.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Warmingup1953
Do you need to (re) create the Nut itself that compresses the olive onto 3/8" Copper tube? Does 9/16 – 24 UNEF sound about right?
benoitmeunier
Intriguing. And that's a good question. I also did a search, but wasn't able to find what this thread is. Here what it need to be plugged to: [Faucet Connector, Braided Stainless Steel-3/8-Inch Female Compression Thread X 3/8-Inch O.D. Copper Tubing Coupling]
benoitmeunier
UNEF? It's maybe UNEF. I guess ... I'll need to test it. How would I know? It's too plugged it to a  Faucet Connector, Braided Stainless Steel-3/8-Inch Female Compression Thread X 3/8-Inch O.D. Copper Tubing Coupling.
MRWakefield
Are you able to take measurements of any parts that you have to hand?
Marcus Wakefield
