Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Does the different shades of blue matter?
2 REPLIES 2
lookhinzaza3004
130 Views, 2 Replies
also why cant i delete the very faded one?
2 REPLIES 2
1. The top sketch is in edit mode.
2.Elements can also be deleted if no sketch is active, which should only be done with extreme caution, if at all.
günther
Drewpan
in reply to: lookhinzaza3004
I would strongly recommend that you do the embedded tutorials in the Fusion Documentation and also some of the
Self-Paced Learning to help you to learn fusion faster and better. They can be found here:
It is also much easier for the forum to help you if you attach your file AND a screenshot of what you want to achieve
and what the problem is. You can create a file to export like this:
While there is no issue with people posting noob questions on the forum, fusion has some great tutorials and learning
resources. The embedded tutorials in the documentation are only one of them. The Self Paced Learning is also really
good at getting started.
Have a look at the three RULES that are pinned to the top of the forum. RULE #0 will be useful to you on your learning
journey.
Cheers
Andrew
Technology Administrators
