For an existing Fusion 360 project, I need to move or remove a number of support bosses used for mounting and fastening that protrude from an irregular curved convex/concave surface. Fusion is down at the moment or I would upload a visual example.
The History on the Timeline has been removed at this point along the work-flow.
The components need to move in to CNC production by the end of the week. There are a number of posts in the IdeaStation, mostly to extrude from the irregular surfaces. If you combine all of the request related to this feature request and its applications, there seems to be a lot of support for it.
Extruding Offset from Surface
Add "to next" option for extrude extents
Enable 'Between' Termination Option in Extrude/Press Pull
While we wait, does anyone have a work around for this that would help???
