Aligning vertical rectangle at 2/3rd of horizontal rectangle
Hi everyone,
Apologies if this has been posted already but I couldn't find it.
If so, don't hesitate to redirect me towards the answer.
I am drawing a bookshelf and would like one of the vertical panels to be aligned 2/3rd of the width.
While in sketch mode, I drew a point located at 2/3rd of the width.
I tried but didn't manage to have the vertical panel to align on that point.
See screencast and link to file below. Any clue on how to proceed.
https://a360.co/31nOKnZ
Thanks in advance.
Best,
g-andresen
1. screencast missing > please try again
2. please share the design
günther
davebYYPCU
You could set this up,
using these names in the relevant dimension of the sketch.
Might help..
That would be a good solution, but usually my full width includes the left and right side panels.
So to calculate 1/3rd of my width I'd have to do (900mm - 2*18mm / 3) and than create a parameter that would be the correct width. I thought there migth be a quicker way to do so.
Thanks in advance!
best
TheCADWhisperer
Did you insert the correct Screencast?
For the question - I would use 3 colinear and equal construction lines.
I would not have repeated dimensions for features that will always be equal size.
davebYYPCU
Change from Join to
New Body, or New Component.
With such a complicated sketch, why would thickness present a problem to you?
TheCADWhisperer
You could also use Sheetmetal tools (uniform thickness parameter) to simplify this even though the material is not sheetmetal.
