Extruding at once multiple rectangles into multiple components
Hi Everyone,
Apologies if this has been posted already but I couldn't find it. If so, don't hesitate to redirect me towards the answer. I am drawing a bookshelf and would like to extrude the rectangles I drew in sketch mode. I would like to extrude all rectangles at once and have them become different components. The way I do it, they all merge into one component, see screencast below.
Any clue on how to proceed?
Thanks in advance.
Best,
davebYYPCU
Reply in other thread.
TheCADWhisperer
Do multiple Extrudes - just like the real world. (Or Pattern.)
(Or copy Components that are identical.)
Found the explanations. Apparently not possible to extrude two contiguous sketches into two components. You need to select/extrude one after the other.
https://forums.autodesk.com/t5/fusion-360-design-validate/extrude-question-multiple-extrudes-join-wh...
https://forums.autodesk.com/t5/fusion-360-design-validate/extrude-multiple-faces-to-separate-bodies-...
