Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
[Script] Import spline from any CSV file
11 REPLIES 11
Message 1 of 12
JeromeBriot
1532 Views, 11 Replies
ImportSplineAnyCSV is an improved version of the ImportSplineCSV script that reads data from a CSV file and creates a spline in a sketch.
This version supports:
  • two colunms and three columns data
  • numbers with a comma as the decimal separator
  • any kind of separator between values
  • automatic text header skipping
Codes and information are posted on GitHub: https://github.com/JeromeBriot/fusion360-import-spline-any-csv
Tags (4)
11 REPLIES 11
Message 2 of 12
@JeromeBriot
Your script works great!
Thank you for not being indifferent to the problems of less experienced users:)
Message 3 of 12
hibaby
in reply to: JeromeBriot
I followed your instructions but the error message comes up like this. What would be the problem?
Please tell me what should I do...:(
Message 4 of 12
JeromeBriot
in reply to: hibaby
Message 5 of 12
jmpframce
how to use the adress you send
thanks
Message 6 of 12
JeromeBriot
in reply to: jmpframce
Message 7 of 12
jmpframce
github.com/JeromeBriot/fusion360-import-spline-...
how to use ?  please  i am fully blocked  in writing a process os desining tool
Message 8 of 12
jmpframce
github.com/fusion360-import-spline-...
est cela qu il faut  copier dans les scripts
merci
Message 9 of 12
jmpframce
How to download
Copy in script first
Message 10 of 12
jmpframce
not
how to  load   i don t get message to past in script
hhttps://github.com/JeromeBriot/fusion360-import-spline-any-csvd
Message 11 of 12
JeromeBriot
New version available (1.1.0):
  • Fix unique separator in CSV file reading
Message 12 of 12
jmpframce
Thanks I will install
It for 3D XYZ?
