[Script] Import spline from any CSV file
JeromeBriot
JeromeBriot
ImportSplineAnyCSV is an improved version of the ImportSplineCSV script that reads data from a CSV file and creates a spline in a sketch.
This version supports:
  • two colunms and three columns data
  • numbers with a comma as the decimal separator
  • any kind of separator between values
  • automatic text header skipping
Codes and information are posted on GitHub: https://github.com/JeromeBriot/fusion360-import-spline-any-csv
Replies (11)
Protective-foam_com
@JeromeBriot
Your script works great!
Thank you for not being indifferent to the problems of less experienced users:)
hibaby
Community Visitor
Community Visitor
I followed your instructions but the error message comes up like this. What would be the problem?
Please tell me what should I do...:(
JeromeBriot
jmpframce
how to use the adress you send
thanks
JeromeBriot
jmpframce
github.com/JeromeBriot/fusion360-import-spline-...
how to use ?  please  i am fully blocked  in writing a process os desining tool
jmpframce
github.com/fusion360-import-spline-...
est cela qu il faut  copier dans les scripts
merci
jmpframce
How to download
Copy in script first
jmpframce
not
how to  load   i don t get message to past in script
hhttps://github.com/JeromeBriot/fusion360-import-spline-any-csvd
JeromeBriot
New version available (1.1.0):
  • Fix unique separator in CSV file reading
jmpframce
Thanks I will install
It for 3D XYZ?
