Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
[Script] Import spline from any CSV file
9 REPLIES 9
Message 1 of 10
JeromeBriot
1062 Views, 9 Replies
ImportSplineAnyCSV is an improved version of the ImportSplineCSV script that reads data from a CSV file and creates a spline in a sketch.
This version supports:
  • two colunms and three columns data
  • numbers with a comma as the decimal separator
  • any kind of separator between values
  • automatic text header skipping
Codes and information are posted on GitHub: https://github.com/JeromeBriot/fusion360-import-spline-any-csv
Tags (4)
9 REPLIES 9
Message 2 of 10
@JeromeBriot
Your script works great!
Thank you for not being indifferent to the problems of less experienced users:)
Message 3 of 10
hibaby
in reply to: JeromeBriot
I followed your instructions but the error message comes up like this. What would be the problem?
Please tell me what should I do...:(
Message 4 of 10
JeromeBriot
in reply to: hibaby
Message 5 of 10
jmpframce
how to use the adress you send
thanks
Message 6 of 10
JeromeBriot
in reply to: jmpframce
Message 7 of 10
jmpframce
github.com/JeromeBriot/fusion360-import-spline-...
how to use ?  please  i am fully blocked  in writing a process os desining tool
Message 8 of 10
jmpframce
github.com/fusion360-import-spline-...
est cela qu il faut  copier dans les scripts
merci
Message 9 of 10
jmpframce
How to download
Copy in script first
Message 10 of 10
jmpframce
not
how to  load   i don t get message to past in script
hhttps://github.com/JeromeBriot/fusion360-import-spline-any-csvd
Technology Administrators
