file name expression
simeonX24F9
simeonX24F9
hello
does somebody know the file name expression?
i want to have the name of the file i am working on always show up in program comment on a new setup......
JeromeBriot
Try this example:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        docName = app.activeDocument.name
        ui.messageBox(docName)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
simeonX24F9
This doesn't seen to work. And it doesn't stay. Next time I go to edit it is
gone
JeromeBriot
I should have read your post more carefully before replying.
AFAIK, it's not possible to use the API to populate a opened dialog.
chris.r.schroeder
Did you ever find a way to do this?  I have been looking for the same thing.  It would be immensely more maintainable to have CAM files matching the part name perhaps concatenated with the setup name automatically.
BrianEkins
Here's a little script that should do it.
def run(context):
    try:
        # Get the design from the active document.
        doc = app.activeDocument
        des: adsk.fusion.Design = doc.products.itemByProductType('DesignProductType')
        cam: adsk.cam.CAM = doc.products.itemByProductType('CAMProductType')
        # Get the first setup in Manufacturing.
        setup = cam.setups[0]
        # Get the parameter for the program comment.
        param = setup.parameters.itemByName('job_programComment')
        # Change the value to the same name as the document.
        stringVal: adsk.cam.StringParameterValue = param.value
        stringVal.value = doc.name
    except:
        if ui:
Brian Ekins
